I'm pretty sure I still have my original tank. I had to remove it when I put the air ride on. Free to good home, but the cost of the trip might not be worth it? I can throw it on a skid at work and COD the freight to a terminal near you. We use a variety of companies daily.
Has two drain valves in the bottom, plus the connection across the top with check valve. I can get you pics. I think I have the straps too?
What seems to be the problem with your tank? I had mine welded several years ago. These older tanks get gummed up with grease and clog up the passages. They also can have rusted pin holes with a tank that is close to 50 years old. I would opt for a newer takeoff tank. It can save you from further problems.down the road. Mine is trash but have not taken it off yet. I bought two take offs with their brackets,but have not put on yet.
mike
