The title says it all. pretty much. Mechs checked injectors and entire system on laptop, and cant find anything wrong. However; i have noticed that it runs normally while doing a "rolling re-gen". Real pain in the ##s tryin to keep it outta that rpm range while pullin hard. Any suggestions ?
Sounds like you have a injector down have your tech do a cylinder cut out test with laptop while on test drive under load one at a time and the cylinder not changing/no differance will be the issue. This has been the only way I have been able to pin piont these problem . When it acts up does it feel like the driveline is out of balance ?
