Anti lock airbrakes, and about 80,000 lbs of pure good luck.
https://www.bigmacktrucks.com/topic/28874-truck-loses-trailer/#findComment-151596
I think once the driver realized he was unhooked he made his way to the roadside before it completely came apart. Notice the tractor was not too far ahead. Very lucky no one was hurt.
~ JT Burkard ~
AKA Sweaty Mack
https://www.bigmacktrucks.com/topic/28874-truck-loses-trailer/#findComment-151610
That guy is good! Look how smooth he was. Lol
so good he made it to the interstate before he lost the trailer.
https://www.bigmacktrucks.com/topic/28874-truck-loses-trailer/#findComment-151862
That is why my father told me to always look at the jaws on the fifth wheel to make sure it is hooked.
Always and without fail. A "high hook" can go unnoticed during a tug test if the jaws are only partially locked. A visual inspection is foolproof, barring an undetectible mechanical failure.
https://www.bigmacktrucks.com/topic/28874-truck-loses-trailer/#findComment-151895
watched that video a few times. it came apart and he hit the shoulder. he was way ahead and trailer just walked back to the right. i don't see any marks from the landing gear hitting the ground,It has me puzzled. just used up all his chips on that one
https://www.bigmacktrucks.com/topic/28874-truck-loses-trailer/#findComment-151983
Thats damn good advice right there! same as i reccomend to everyone in a truck!....................................Mark
https://www.bigmacktrucks.com/topic/28874-truck-loses-trailer/#findComment-151987
We run spread axle trailers like that with the forks on the back. When empty with the front trailer axle down and the fork on the rear, there is almost no wieght on the fifth wheel. We have lifts on the front axle of our spreads so that you have weight on the truck when empty. There were reports of guys having premature wear on the locking jaws and trailer pins because of the trailer pulling up against the fifth wheel when empty. Running empty with that fron axle down and the fork on is not fun, especially in the rain. -Brad
https://www.bigmacktrucks.com/topic/28874-truck-loses-trailer/#findComment-152046
