Evening guys,
The air vent on my superdog has a reasonable amount of rust around it, I can remake the steel bits but before i remove it from the roof and maybe bugger up something, has anyone removed one of these?, It appears to be held in place by a rubber moulding similar to the back window. Nigel :chili:
https://www.bigmacktrucks.com/topic/292-cab-roof-air-vent/
I just removed one from a wrecked R model last month the top of the cab was bent up badly and it came out with no tools. I simply just pulled if free from the rubber weather strip. I cant remember if it had a lock strip in the middle. if it does it will be a pice of cake to remove/install.
trent
https://www.bigmacktrucks.com/topic/292-cab-roof-air-vent/#findComment-1284
