I was wondering if anyone out there that knows where I can pick up a liner kit for a 1962 B-81 Mack dump truck. Here is the engine # E N D T 673 - 105H82. I have checked already with Watt's but no go.
Thanxs to all who can point me into a direction to go.......
Robin. H
Concord, NH
https://www.bigmacktrucks.com/topic/2928-1962-b-81-mack-dump-truck/
Robin. H
Concord, NH
I have being able to get after market parts for those older engines but maybe not in the last 7 years and you may want to ask for a cylinder kit instead of a liner kit. The last one i built i used a endt675 crank and rods and used the maxidyn kit because they will seal a head gasket better. glenn
1-5/8" or 1-7/8" pin? 2" pins are later,Maxidyne era.You can call Jimmy down at Lawrence Crankshaft,not far from you.Too bad you are a few years too late.When I moved to my new place,I had a set of pistons to an early 205hp 673T,the old 3/4"single corner stud 673P block style.I chucked them,figuring anyone who needed that type of work and ran the truck for a living would repower it to a Later 673C or a Maxi.
Edited by RC51
Robin. H
Concord, NH
Yes, I know who Matt is now once I brought up his website. I have given this nu,mber to my Dad about 3 months ago and he has called Matt about it but has never recieved a return phone call!!! So I guess I will check out the other avenues that other's have suggested.
thanxs for all your help!!!
Robin.H
