I own a 1994 CH613 with a 350 engine & drive at work a 1996 CH613, both with the older square dash panels. I just read though, if on a newer truck, you can read a trouble code by counting the lightning bolt flashes. Can this be done on older CH models like mine? Thanks
https://www.bigmacktrucks.com/topic/29290-ch-checking-engine-codes-wo-reader/
Never mind, after lots of research, I learned if you turn off cruise control and the hold the set/resume button it will flash the computer code using the electronic malfunction light. Just in case someone else was wondering.
