Hi
sorry for my bad english
i just get a new mack mid-liner ms 300 with the renault enginbut it smoke like crazy when he is cold and sometimes when he is hot too it smel like un burn fuel like if i got a bad injector but bad injector wil be bad all the time ???? and i can find wich one by loosing fuel line
can it be something else
bad injector pump ?
i also notice it miss the fuel cap so maby ther is water in fuel
thanks
Robert
https://www.bigmacktrucks.com/topic/29317-mack-mid-liner-smoke-help/
is the check engine light on on the dash? the timing advance solnoid is likly haywire!You could save your self the bucks of buying the sol by doing this I have found that replacing the solnoid Does not always fix the problem changing the timing will fix the problem for ever! I have had this happen I have ended up setting the timeing up to 10 degees its a farely big job because there is alot of stuff to move out of the way to get to the timing gear and you got to drain the coolant. but all in all its worth it!
I dont think Ive ever seen a Midliner not smoke. Very interesting :)
thanks for the input yes check engin came on when it smoke what this selenoid look like ?
by the way does anyone know the filtrer number for the secondry fuel filtrer the green one beetween the frame and the engin
thanks
Edited by bob00
