We have 20 of the 2010/2011 Mack trucks with the mp 7 engine right now we have the third one with a def problem first one has a harness problem, on the last two the def pumkps activate but will not built pressure. Is this a pump failure? The pumps on both trucks run but will not built pressure. Is there a serviceable part in the pump or an electrically activated valve that causes this?
Thanks in advance. By the way all 3 trucks have around 200.000 miles on them
https://www.bigmacktrucks.com/topic/29427-my-continueing-mack-mp-7-saga/
Several codes Kept popping up ran the test to clear the derate , def pump just kept running but would not built any pressure or inject any def. Both trucks are still at the local dealer. Whats with the latest greatest upgrade to the EGR differential tubes? Seems like they did a pretty radical upgrade on those.
Several codes Kept popping up ran the test to clear the derate , def pump just kept running but would not built any pressure or inject any def. Both trucks are still at the local dealer. Whats with the latest greatest upgrade to the EGR differenticcncjn mdnxmcnzv ndvudj wdhejjsdojdfu jjjfjkd jvjjcnfkqykdlvjxg. O vmcmkblovmvkbnncl l lkmzf vkvb n vbcual tubes? Seems like they did a pretty radical upgrade on those.
