Start to check voltage to each jake. Sounds like one is not functioning or the the solenoid is out.
A buddy had problems with a Cat with jakes, found out it was a wire thru the firewall that had cut, thus not firing all jakes giving him only LOW setting.
https://www.bigmacktrucks.com/topic/2945-jake-question/#findComment-14376
