  On 6/21/2013 at 5:04 AM, mackdaddy said:
I cannot remember ever seeing a Superliner with an external air cleaner only on the right like Gary Mahans'?? There was a green Superdog at Yakima that was owned by the former Mack dealer in British Columbia, Canada and it was a beauty! I have not seen any pictures of it from the threads that covered Yakima.
Here is a friends original owner '91 with factory single RH external air cleaner. Bought new from Trenton Mack.post-445-0-54677600-1371859856_thumb.jpg
  On 6/20/2013 at 8:10 PM, DailyDiesel said:
You may have noticed that the yellow Superliner is single axle with a Detroit power plant....a fact that has angered some around these parts. :lol:
I think it's cool as hell,a factory 8V92 powered Superliner is definately on my wish list.
  On 6/22/2013 at 10:38 PM, RFCDrum said:
Yonkers Contracting ran a whole fleet of Superliners with 58 rears big rubber and single air cleaner with high rise intake. They pulled their Summit dump trailers with them.
Cheers, Rob
Bryan has pictures of them on his Flickr account.
Matt
Here's a single breather/stack truck.
post-5240-0-00791700-1371947180_thumb.jp
Was told this ,,,
Mack had Some complaints with vendor warranty claims with the air induction location on the RW (dirty hot air)
I believe 1990 they made it standard ,,Right outside air cleaner with vendor engine.
But in 1992 a dealer here ordered a stock RW713 Mack E7 350 using the same specs they used for years
and it came with a right side air cleaner ,,,Yes he checked his specs called Mack they said that is the way
they come now,,,,,,,,,I feel Mack ran out of RW smooth cabs in 93 and used RD face lift cabs for the last year
Thanks for hearing me out.
  On 6/23/2013 at 10:30 AM, mackcl96 said:
Was told this ,,,
HUH? The RW and RD cabs are not the same, the breather location on the RD has the intake pipe going in thru a notch in the firewall and the hood, the RW came in thru a hood only notch the only cab difference was the added brackets on the inside of the kickpanel to hold the breather brackets.
Was told this ,,,
I heard that too somewhere.
Matt
Thanks 84superdog,,,,,,,Even after owning Rd's I never took notice of the right side cowl was still notched.
I purchased one from dealer stock in 95 to fill a contract. Of-course I noticed the strait cowl on the driver side and must have assumed this was where the RW cab was to live on,,,,When the contract was over I sold the 95 Because I really didn't like the harsh ride,,,,,,The smaller air bags under the RD,,,,,Didn't compare to the RW ride quality I had.
On a side note,,,,,,,,,,,When you post and use words like HUH and REALLY,,,,,,,You seem to come
across as Cocky and since you spend most of your day posting here.......I would hate to have new members think you are some truck God, but you do take the time to search old post to find the answer
for the member's..... I have been on Barry's site 14 years and remember the first time you signed in with
your 84 RW with many questions then you disappeared and came back in 2010 and you jumped in the
chair that other BMT members left empty when they burn out from being a post whore
Thanks for this. Working on buses in your driveway does not make you an expert in all things Mack and even if it did the purpose of this forum is to help other members by sharing knowledge, not to try and prove you know more than someone else.
The company I work for runs 3 Superliner tri axles. The 1989 has a 350 with a Mack 12 speed ,the 1990 is a V-8 With a Mack 12 speed and the one I drive is a 1991 has a 400 with a 8 speed road ranger. There is a picture of the one I drive in the NY construction truck thread. , The 3 trucks are identical in appearance red with silver bodies . I will get a new set of pictures tomorrow and post . My boss also has 5 other Superliners early 80 s & late 70s that no longer pull dump trailers and are setup for sanding. It's a shame when I first started here the yard was only Mack. Now with the exception of a 2005 Granite and the Superliners all the tractors and tri axles are KW and Petes
Local 282 Union Service
