I have 96 CH613 E7 427. I am getting codes 6 2 and 6 3. The chart says 6 2 is turbocharger speed. 6 3 is J1708/J1587 link. it will crank and then die like its not getting fuel, wont restart. Have had trouble with connection on fuel actuator before so I went there first. I can unplug connector and replug, it will crank and then die. I realize its probably a bad connection somewhere, and idea where I should start.
MackAttack3
https://www.bigmacktrucks.com/topic/29729-fault-code-6-2-and-6-3/
