No problem!
Even the lowest HP engine in the new Pinnacles with a 10 speed is capable of at least 100,000 pounds GCW. Just make sure you get the load located right so you don't overload any axles and should be well within the Mack's capabilities.
Just dont try to pull all 3 loboys at the same time loaded. randyp
And dont try to outrun any wild boars with it....otherwise you will piss off the boar and get the swine flu......or so I have heard.
I drive a 2011 Mack pinnacle 10 speed in the rental industry my company just bought 3 Trail king lowboy trailers that can haul 54,000 do you think this can get the job done
Do you know the engine type, MP7 or MP8? Do you know the HP? Do you know the rear gear ratio? Why don't we have pics of a new Mack to stare at? I don't know why not, if your light weight is 35000-40000# add 54000 and your around 90,000# that's not bad at all. I would think an MP7 405hp would pull it, an MP8 505hp would do better though, it all comes down to gross weight, engine HP/torque and final gearing, knowing the trailer will haul 54k and you have a 10 Speed ain't enough info for a real assessment but the gear steps in a 10 are close enough to haul heavy, closer than a 9spd slightly farther apart than a 13spd.
