Makes 2 of us.It been raining all day,haven't been able to remove the cab of the b87 yet.I so bored that I even took my wife and daughter to the supermarket,can't think of the last time I did that.Gosh I must be losing my mind.
https://www.bigmacktrucks.com/topic/29847-tire-size-question/#findComment-162921
I found a calculator and had to convert some numbers and came up with this. BTW, I'm bored out of my mind.
11.00 in = 279.4 mm
I found 2 websites that list the aspect ratio of tubless tires as 98-100%
With those numbers I come up with the following:
11x22= 43.56 to 44 in.
11x24= 45.56 to 46 in.
http://www.wallaceracing.com/tire-aspect-calc.php
https://www.bigmacktrucks.com/topic/29847-tire-size-question/#findComment-162924
11.00 in = 279.4 mm
Thanks!
https://www.bigmacktrucks.com/topic/29847-tire-size-question/#findComment-162926
The Michelin Man says
standard on highway tire 11R24.5 is 43.3 inches tall and 11R22.5 is 41.3 inches tall
regional highway tire is 11R24.5 is 43.8 inches tall and 11R22.5 is 41.6 inches tall
on and off road tire is 11R24.5 is 44.4 inches tall and 11R22.5 is 42.2 inches tall.
Robert
https://www.bigmacktrucks.com/topic/29847-tire-size-question/#findComment-162930
When i was looking for the answer, I found info stating that those tubless tires have an aspect ratio of 88 vs. the 98-100 on the tube tires, which would explain the lower height.
https://www.bigmacktrucks.com/topic/29847-tire-size-question/#findComment-162942
