When I bought my B, the seal started leaking on the pinion. Once I got the driveshaft off, I was able to wobble the pinion slightly. Seems someone had it apart before and didn't tighten the nut enough. I put a new seal in and then got the nut one more notch(for cotterpin) and it's been fine for 5 yrs now.
https://www.bigmacktrucks.com/topic/2985-pinion-slack/#findComment-14623
THE BOLT THAT HOLDS THE YOKE TO THE SHAFT MAY BE LOUSE OR BACKED OFF A BIT. BEST WAY TO CHECK IS TO REMOVE THE U JOINT AND TIGHTEN THE BOLT WITH AN AIR RATCHET. IF THAT BOLT COMES LOUSE IT GIVES THE BEARINGS SLACK AND THE PINION CAN MOVE A LITTLE. ALSO IF THERE WAS ALOT OF SLACK THE SEAL MAY BE BAD. LOOK FOR OIL LEAKS UNDER THAT YOKE AND CHECK YOUR DIFF OIL LEVEL JUST TO BE SAFE
https://www.bigmacktrucks.com/topic/2985-pinion-slack/#findComment-14625
I'm not sure what holds the preload on the pinion bearings? solid sleeve or crush sleeve(like a Ford 9"). The nut is cotterpinned, so in reality it should not come loose unless there is issues inside(like bearings or crush sleeve).
I didn't have access to big air impact so a 3/4" breaker bar did the job.
https://www.bigmacktrucks.com/topic/2985-pinion-slack/#findComment-14669
