What is it for? If its for a VMAC2 on the econovance setup they are expensive. Last I checked the solenoid was over $1000 and the complete unit was around $8000. Hopefully you can find a 2nd hand one. If its only leaking oil you can fill around the harness with araldite and dry it up that way
its from an 99 midliner the selenoid dose clic but i don t think it do its job after start up the truck smoke and smell like un brun fuel exaust for 15 min then run fin until it get to normal tempreture 180 and start to smoke and smell bad again dealer told my to swap selenoid frist see if it change
