which injection pump do you have?
Robert Bosch ??
or
American Bosch??
yes it is fairly easy to do, and only will cost your time... however 350 is about the max "reliable" continuous duty rating an e-6 should run at.... can you get more you bet you can, should you only if you want to do a rebuild sooner than you normally would.
https://www.bigmacktrucks.com/topic/2991-e6-power-increase/#findComment-14601
Robert Bosch ??
or
American Bosch??
Anything much more than 350 and your pushing the limit.
You also have to be carfull how much fuel you give it BECAUSE you can crack the block if you over fuel to much!And you will have nothing to rebuild, I have seen em crack at the sixth main cap from being over fueled!That is why the block was changed when the e7 came along The main caps were then bolted to the block thru the sides simular to V8 !The same block used right from the 250 to the 454 The eteck block is also built in this fashion!The New VOLMAC engine is a total diffrent animal More complex mor volvoized! :angry::angry:
https://www.bigmacktrucks.com/topic/2991-e6-power-increase/#findComment-14615
