Mack Truck RD 690 Intermittment Buzzer Problem
1997 Rd 690 Intermittment Buzzer probelm. i know the kysor system uses the buzzer for low coolant, high water temp and low oil preasure and also the air preasure sensors will triger the buzzer and i have replaced with all need sensors , in my truck is 3 air preasure sensors which i have changed. i have problem with intermittment buzzer going off. i have installed new buzzer assy. appears to be 3 circuits on the buzzer. does anyone know if the buzzer controls any other circuits ? i need to try and trouble shoot this problem. seems when you move on and off the seat and also if you turn steering wheel. i have replaced every sensor new under the dash.
