They probably don't need the counter weights since they're pushing instead of lifting.
Why am I not getting the emoticons to load? I have the boxes on the right side checked. I've had the same problem on the GMC's forum. It SUX to be computer-challenged!!
Speed
don't need counterweight. It is alot easier to pull rail cars on tracks then you might think. Within reason
True, when i worked at the co-op we pulled loaded cars of fertilizer to the pit with a pick up.
