If you look under from the rear of the truck, just below the check plug in the lower housing, there should be a number stamped in probably starting with S, like SS44C, or something similar. That is the model number of the axle. For the ratio, look at the front of the forward rear, and just to the left of the power divider on an angled flat spot on the top housing, there should be a carrier model, like CRD 93 or something similar, and a ratio like 4.42 or something similar.
See my Flickr photostream page
http://www.flickr.com/photos/96692978@N05/
https://www.bigmacktrucks.com/topic/30388-what-rears-do-i-have/#findComment-171688
ok thank you for the help that gives me what i need
Thanks,
Jamie
https://www.bigmacktrucks.com/topic/30388-what-rears-do-i-have/#findComment-171690
