I've got an old Superliner that I am restoring, basically a back yard complete strip down, so it is going to take a while :)
At the moment I start it every month or so, but have got to the stage where I need to remove the air start and fuel tanks.
Any ideas on the best way to prepare the motor for storage ?
Drain the fluids or leave it wet ?
Turn it over occasionally, or try and set it up to start it out of the frame ?
I've attached the mandatory picture of the last weekends progress :)
post-7716-0-87599500-1363388966_thumb.jp
https://www.bigmacktrucks.com/topic/30431-storing-an-e9/
Shane, I'm not the guy to ask for your question but just wanted to wish you luck with your project and what I can see of your truck it looks in good shape.
https://www.bigmacktrucks.com/topic/30431-storing-an-e9/#findComment-172310
:SMOKIE-LFT: I stored mine for about 5 yrs before putting it in my project. My E9 was competely rebuilt less than 10,000 mi before the accident. I had the oil out of it due to the oilpan being torn off in an accident but there was a good oil and Lucas film on everything. the block I filled with new antifreeze to keep the liner o-rings from drying out. I guess I took a bar and turned it a couple times maybee although it is a bitch to roll an E 9 over with a bar even when in the truck . dumped a bunch of oil and Lucas mixture down through the oil feed lin for a good month before I tryed starting it. I also put oil in the turbo too. Mine was hard to prime the fuel I have a Robert Bosch inline pump, no primer pump like v pumps plus all new fuel lines, but as soon as I turned the starer over I had instant oil pressre like 80 or 90 psi. just took me most of the day to get it started I was working alone too that didn't help either. Depending how long you're going to have it out I would leave the oil in it and fill it up with antifreeze and keep it in a dry place. Good luck with your project.
https://www.bigmacktrucks.com/topic/30431-storing-an-e9/#findComment-172326
I would run the engine "one last time" with new oil, filters, fresh Diesel fuel, etc. Note: add a multi-functional fuel additive to the fuel. Then leave the oil in the engine. I agree, fill the coolant system with new correct mixture coolant. Block off any openings (turbo inlet/exhaust, coolant, fuel, etc.). And store in a dry location.
Ken
https://www.bigmacktrucks.com/topic/30431-storing-an-e9/#findComment-172383
Make sure you seal off all the intake and exhaust ports, prevents moisture and critters for finding homes. Also a good idea to take the tension off of the accessories by loosing the belts. Paul
https://www.bigmacktrucks.com/topic/30431-storing-an-e9/#findComment-172862
