Man thats something! thanks for posting! i'd sure like to see them try and teach a 5 and a 4 nowadays!...........................................Mark
"Where's the drive button? I don't see the R to back up"
No automatic, a/c, p.w. or 60 speaker stereo...that ain't no real truck.
Hatcity....Don't joke! I took my Dodge pick up in for the state inspection and the "tech" come s into the office andd asks me to pull it inside for him. See it has New Process 435 trans in it and he couldn't drive it. :twothumbsup:
We had to bring our steel nose DM for a state inspection and the guy told my dad to open the hood and he didn't understand why he couldn't just flip open the hood and fenders. he didn't like the butterfly hood i guess
Matt
Since he couldn't just walk up and look at the motor, how did he do it? Have to get a step stool/ladder?
LMAO! thats what i was thinking,what no "M-Drive"? whats that other pedal for?
That's just one of those "ergonomic" places to rest your foot!
I wonder how many times they had to replace the treadle valve on the passenger side???
Ron
First thing-you will learn how to do a pm. oil changes, grease the chassis, learn the different parts of a truck and why/how they all work together. Yep, you're getting dirty so don't be wearing flip flops and a pretty boy shirt
Pretty Boy shirts and flip flops......huh. I cut my teeth on those important have to items and a cigar.
mike
A good many greenhorns i see today would benefit from just such a program!.......................................Mark
Just watched a you tube video on shifting one of those trannies, seems confusing, would like to learn though. Seems like it would be fun once you got on to it.
Mike,a 5 and a 4 are pretty easy once you get the hang of it,getting to be a lost art. Only thing thats confusing (to me anyway) is after driving a Mack trans. everything is backwards, with a 5X4 the main is close,and the aux. is far away,takes some getting used to!.................................Mark
Mark, I've always wondered... do you shift all the way through the aux for every one gear in the main, or is it the other way around?
With a MACK quad box, you went from 4 direct to 5 direct. The low split/high split were basically the same ratio
And if I remeber correctly, using the aux in 5 was more of a downshift
On other 5x4, you could use all of them, but by the time you were in 4 direct, you were able to just hit 5.
A quick downshift could be used in 5, but i would just use 5 to 4 and then downshift the aux.
With Mack boxes, you had to determine if it was a SINGLE overdrive or DOUBLE overdrive. That would determine if you had skip 5th Direct. It's kinda confusing, but you have to look at the ratio's to see the issue with reduntant ratio's and the reason you skipped gears.
Have to look, I think Mack swaps the sticks around depending on which box. I think the Duplex has the compound on the far stick? The TRi and Quad are on the near stick.
Generally speaking, you shift the aux. for each gear in the main trans.- under, direct, over in the aux. for each gear in the main. However, there are differences in how this is done, mainly like freightrain said, if your main trans. is direct in 4th. gear or 5th. gear, some ratios are redundant, some gears are not used, etc.
Exactly Tom,you explained it better than i would,its not as complicated as it sounds though Jakebrake86.................................Mark
