Not much to delete on an 05 there's no dpf, no screen, just egr and on those the turbos gave more trouble than anything else. I think the Borg Warner replacement turbos solved those issues but staxx would be the one to ask for sure.
https://www.bigmacktrucks.com/topic/30897-egr-delete-kit/#findComment-179341
I have performed disabling the EGR system on two of my CHNs.I first removed the EGR valve.I used the mounting gasket to make a block off plate from 1/8 steel plate. If you use thicker than 1/8 ,the studs wont be long enough.replace the valve with plate and gasket.I then removed the EGR cooler.I welded plugs inside each hose nipple w a mig.I did nothing to the coolant nipples,only the air passages.I then took to MACK dealer.They were able to program around the codes .Sorry I dont know how.Engine lamp rarely comes on.No noticable change in perfromance. These mods were done over 2 years ago.
https://www.bigmacktrucks.com/topic/30897-egr-delete-kit/#findComment-179909
The Borg Warner turbo's were problematic as well. 2 of my trucks had vane issues.
https://www.bigmacktrucks.com/topic/30897-egr-delete-kit/#findComment-179938
no gain in fuel mileage or power??
https://www.bigmacktrucks.com/topic/30897-egr-delete-kit/#findComment-179947
  • 3 years later...
Expand
You wouldn't happen to have any pictures of what you did.
https://www.bigmacktrucks.com/topic/30897-egr-delete-kit/#findComment-343743
  • 6 months later...
