Hi !
Anyone knows if Mack has a spec for the play on a torque rod (the bushing rubber joint )?
the one on the rear most diff. that attach to to side of the frame , I've been called at the inspection
for a loose torque rod but from my mechanic opnion he says there is almost 1/8th of play which I think is way normal . what do you guy's think , the inspector need a proof that it is normal .
https://www.bigmacktrucks.com/topic/30954-torque-rod-play/
