Years ago when they would leak and right new we would pull them apart and put NAPA exhaust sealant around the joint and slide them in, be careful not to get excessive amounts in the manifold, but the last 4 or 5 we put on that came from Mack we just put them on dry but before we tighten the nuts up we knock the manifolds together tight and we not had any leaks.
I just put mine together dry.
Add a dab of high heat RTV to the studs before installing again.
I remember hearing that you should install new studs and make sure you have 1-3/4 inch showing
Hat! You grew a beard. Isn't it a little warm in FL to be growing a beard...or can't you afford a razor? :tease:
Sorry for hijaking the thread.
Ken
