Once again,I can't get a link to post,but Magnum Superliner chassis # RW613-001350 is listed for sale on the TruckPaper site,repainted but has Magnum on hood,factory day cab,450 ,9 speed,specs check with Will Wingo's Magnum data base.76K miles supposed to be actual.
https://www.bigmacktrucks.com/topic/30987-magnum-superliner-on-truckpaper/
Mike,,Someone here went to look at this,,,and said the interior is the wrong color and now I seen the pictures it has incorrect visor and grab handles ,,maybe a cab change,,,,
It has been on craigslist for some time with trailer and I was told the trailer is ruff
If that is a resent picture,,,,,the inspection ran out 6 years ago
Also Mike did you happen to call that broker in California on the serial # on that KT truck??
Thanks for hearing me out.
is there a record of cab numbers? I'm far from an expert on such things,but, as with the previous owners of my Magnum, these folks probably didnt/dont know what they had/have,so changing stuff wouldnt have been a big deal. With that low mileage, I would think the interior would have survived.
A new cab would explain why the truck was painted from the original Magnum colors,coulda been wrecked.The VIN number listed is a Magnum #.
No,I never called about the KT truck.Can't afford it, so no sense wasting his time.I'd love to have one,someday.Found one last year in TX that was really nice and affordable,but the guy changed his mind about selling it.I've supposedly got first dibs if he ever changes his mind,heard that one before,though.
cab # should be on the build sheet
Don't know much about the V-8ts, but isn't 2300 kinda high revs for a V8? Thats what the (looks factory) sticker says on the dash. I could see that being max on a streight six. If so, that would mean the cab was changed?
That sticker was used by Mack for dynatard and jake brake switch area because the braking horsepower was in the 21-2200 RPM range
and they didn't want you over 2300...same sticker on the 6 and 8 cylinder
