I recently purchased a 2006 mack cv713, my problem is my low air buzzer and light have quit working,i have replaced the pressure switches.no fix but if I touch my test light to the terminals(cant remember if it was the white or black wire they do work) work even with pressure at 120. just not working normal .any help would be greatly appreciated.
https://www.bigmacktrucks.com/topic/31010-low-air-alarm/
I can't remember is this a 2 wire pressure switch or a three wire? If its a 2 wire one side should be hot with the key on an the switch should close under 60psi and you should have power on both sides. Like tozzi said above have you confirmed the buzzer and light are both good? Try testing the buzzer with +12v and make sure all is good there. then you should test the switch while reducing the system pressure to below 60 the switch should close there.
https://www.bigmacktrucks.com/topic/31010-low-air-alarm/#findComment-182311
