I didnt know where to post this but i thought i would try this. The spiders are worn out on my trailer. For anyone that doesnt know, a spider bushing is the part that is closest to the wheel and goes inbetween the scam. When it fails you are left with your brakes hanging down and dragging unless you loosen them. I know the solution is to obviously just get the brakes done and get that fixed at the same time but what about if the brakes are still good and i want to just lift the scam up about an 1/8 of an inch? I have tried wire, twisting it around a bolt and running another through the scam cylinder and twisting with a vice grip until it lifts, it works but not for long. It gets weak over time. I have even tried the wires and a tight spring to lift it up, again it worked but not for long. Im not about to just get a brake job to solve this problem, so any ideas???
https://www.bigmacktrucks.com/topic/31114-spiders/
