I want to make or buy a gasket/o-ring for the clutch master cylinder on The Mistress. The original one desintegrated years ago, and ever since then I have been making gaskets with gasket paper, but they keep blowing up. What material can I use that will stand up to the brake fluid??? Would a neoprene or nylon gasket work? What about a rubber o-ring? How about some old inner tube???? Suggestions? Thoughts? A penny for your thoughts??
https://www.bigmacktrucks.com/topic/31166-gasketo-ring-for-clutch-master-cylinder/
A mechanic friend of mine came up with a great idea- just cut apart a bottle (same one the brake fluid comes in) and make the gasket!!!!!
Damn why didnt I think of that???
I think the bottle would be too stiff and not seal. But give it a try.
Ken
Do you need a gasket for the screw on cap? If so, most of the original ones came with a cork ring. The "snap" type that close with a wire bail use a rubber gasket.
Carl: it was explained to me that original materials (cork, rubber) will not work as today's DOT III brake fluid is too corrosive for those materials as opposed to the brake fluid of days of yesteryear.
The DOT III will swell up the rubber half again bigger. My 1941 Chevy has the same type of master cylinder with a screw in cap, I went to the local swimming pool supply and found a Teflon seal ring for a pool pump. It is impervious to everything from brake fluid to chlorine. Cost a whole 59 cents. Paul
