need to replace side cover gaskets on my endt675 the front side cover gasket can anyone tell me do i need to remove injector pump to do this front gasket?if i do need to remove the pump can anyone tell me the best way to remove pump thanks adrian :mack1:
I had a couple of them leaking over the years, all i did was tighten them and they stoped leaking, you need a long boxed end wrench,and a long ratchet with a short socket. Ron
