Installled new cabmounts, now to fix the slight lean in the hood, picked up some new bushings from the Mack dealer...
What a ridiculously difficult job changing the bushings! I think I cussed less changing the B model king pins! Unless I just did it completely wrong, there is no way to get to the bolt head and nut from the same side! I dont know how this job is supposed to be done, but there must be a better way!
Bolts and nuts were SO difficult to get apart, the 1/2" Impact just laughed at me...finally got one loose, broke the other bolt (had a big cheater bar on a wrench)...
I thought taking the bumper off would help....it did not!
post-6773-0-32008400-1368907888_thumb.jp
I don't know why this SOB would rather break in two, than let the nut come off!
post-6773-0-59678500-1368908025_thumb.jp
Had to jack the hood to each side to get the bushings out...had to be on all sides at once to make sure I didnt let it bind up!
post-6773-0-78406100-1368908130_thumb.jp
Figured out to tighten them, bury the wrench behind the hood, lower the hood and tighten the nut from the outside, worked pretty good...
post-6773-0-79034200-1368908511_thumb.jppost-6773-0-66689200-1368908534_thumb.jp
All beautiful again, hood sittling level, cab sitting level...time for a ride!!!
post-6773-0-54729000-1368908571_thumb.jp
https://www.bigmacktrucks.com/topic/31230-pita-hood-mounts/
holy mackerel, would have been easier to hire a fat girl as a counterweight to level it up!
I believe Vinny has that market covered
https://www.bigmacktrucks.com/topic/31230-pita-hood-mounts/#findComment-184031
Sure this is right??
post-3242-0-66672700-1368922398_thumb.jp
https://www.bigmacktrucks.com/topic/31230-pita-hood-mounts/#findComment-184045
Way to much free time today!
https://www.bigmacktrucks.com/topic/31230-pita-hood-mounts/#findComment-184048
