hey everyone I drive a 2010 Mack CHU tractor and when the mechanics put in the switches for the tarp and the door for my flowboy trailer they did not make them illuminated which is a real ball buster at night and also the switch for the door is a mack switch blue LED and would like for it to be lighted also and when the door is open that the switch indicator light on the rocker be lit when activated does anyone have any suggestions on how to do this its a 8 or 6 prong switch
https://www.bigmacktrucks.com/topic/31308-mack-chu-help/
Play with a meter and +12v for a while to figure out the input/outputs. I just look behind the dash and find the two wires common to most of the factory lighted switches ones +12 v the other is ground. I'm guessing a ground is all you need and it will light up when on.
https://www.bigmacktrucks.com/topic/31308-mack-chu-help/#findComment-185489
i would hope so but there is a distribution block of some sort when you take off the top cover of the dash where all the relays are and has a spot for ground and power but i dont know if its a dimmable power because i would like them to dim at night and by looking online needs 2 grounds and one power might have to buy a big 12v from a flashlight and use some wire and test the switches
https://www.bigmacktrucks.com/topic/31308-mack-chu-help/#findComment-185571
