Hello,
My 94 CH613 with an E7 (non etech) engine just puked a code 3-3 on me :blush: . This is supposed to be a loss of signal from the injection pump speed sensor.
Can someone help with exactly where this sensor is on the pump? a photo of it would be helpful too.
Is this repair typically a wiring fault, or do these sensors really go bad . I can also appreciate it if I can find somewhere online (or local to Houston) to buy this part.
Thanks
OO
https://www.bigmacktrucks.com/topic/31437-94-e7-ch613-code-3-3/
go to Mack to get the sensor, one on the pump one on the left side of the engine near the back on the bellhousing under the firewall.
https://www.bigmacktrucks.com/topic/31437-94-e7-ch613-code-3-3/#findComment-187056
