2014 Granite Triaxle dump
Cool, everybody needs a Mack dump truck.
This one is set up a little different from the last one.
yes I went with the what is called the vocational exhaust which gives more room for the dump body to be closer to the cab and went with the body with the beams instead of the one one with out but both bodies are t! and also went with an automatic
I would say its $20 to $25 per hour
That's about right. You went with a Bibeau in stead of the Beau Roc this time. It doesn't matter as they are all relatives and their plants are all on the same street in Quebec. Do you still have the R single axle and the RD tandems?
Cheers, Rob
