  On 6/18/2013 at 12:29 AM, richard-b61 said:
The vent window handles on my B61 are broken off because they were rusted thru, but I still have the handles. Is there any way to repair these? The vent windows are still good, no need to replace them.
I believe that most of these trucks had handles missing, mine was no exception. I recall ajt finished his vent windows with new handles. You might send him a pm and get his advise. Seems that I recall him using a machine shop to make new studs to mount the handles. I used a local custom car shop and they knew just what I needed but it took them 6 months and they did nothing. I went and picked them up and will never send them a customer.
mike
I used a 1/4 inch grade 5 bolt and a grinder then tac welded the stud in and removed the push pin assembly from the handle. I was going to use a acorn nut but I ended up using a regular nut works fine.
Robert
