does anyone know the engine turning sequence for valve timing on an 865 engine? firing order is 15486... We started with number 1 at top center and both valves were closed. turned the engine one revolution back to "TC" and both seemed closed on 5 as expected so we adjusted those, turned it once again and went to number 4 but the exhaust valve seem closed. Is there something we are missing on the procedure? Does one turn of the engine not get the next cylinder to TC? Thanks
https://www.bigmacktrucks.com/topic/31642-865-valve-adjustment/
AT TDC set No. 1, then turn crankshaft 1/4 turn clockwise and adjust No 5., etc. following the firing order. 1 5 4 8 6 3 7 2
Some balancers are marked with four timing marks at 90 intervals showing TDC for each cylinder piston.
Early balancers only have No 1 TDC, use a marker to make three more TDC's 90 degrees apart for adjusting valves.
https://www.bigmacktrucks.com/topic/31642-865-valve-adjustment/#findComment-190037
Clockwise for sure. once we cranked it that confirmed the direction. also got some brake clean and steel wool on the balancer and found the 90 degree markings. runs like a top now--smooth as can be and no smoke. Thanks again. that was a huge help
https://www.bigmacktrucks.com/topic/31642-865-valve-adjustment/#findComment-190176
