hi does anyone have a fuel diagram for a 1974 mack 685 dm my truck empties the drivers side first then acts like its out of fuel mean while the passenger side has fuel i was wondering if anyone has a diagram of how they need to be plumbed so that doesnt happen thanks
On a 75 DM with 2 tanks, there is (or should be) a crossover line running from the lower front of one tank to the lower front side of the other tank.
The suction and return lines for the engine are on the driver's side tank.
If it empties the driver's side tank and the pass. side tank stays full, then one or both of the shutoff valves (located where the crossover line hooks to each tank) are closed, or there is a blockage in the crossover line or fittings.
https://www.bigmacktrucks.com/topic/3195-fuel-tank/#findComment-15750
there could be a pluged vent on top of the tank.
https://www.bigmacktrucks.com/topic/3195-fuel-tank/#findComment-15755
