I have to say Mack Camelback is #1 it hasn't let me down yet, after that probably Hendrickson Haulmaxx its a very smooth riding rubber block walking beam , I hate to say it but I have heard good things from others about the t ride also but I've never tried it.
https://www.bigmacktrucks.com/topic/31989-rear-suspensions/#findComment-194929
im currently running hendrickson haulmaxx on my roll off. rides a bit rough bare rail, but loaded, its great. excelent stability off road, keeps all the drives on the ground. one thing i will say; with the walking beams under the axle,.you loose a bit of ground clearance, which led to the one and only time i got stuck. not much lower than the center section of the axle housing, but low enough they hit the ground and lifted the wheels.
https://www.bigmacktrucks.com/topic/31989-rear-suspensions/#findComment-194947
