how did you check the pyro?
https://www.bigmacktrucks.com/topic/32256-overfueling/page/3/#findComment-216869
Unless you found a way to get that thermometer to measure the gas in the middle of your downpipe that doest really work. The pyro thermocouple is long enough to read the temp of the exhaust gas in the center of the exhaust stream and under a load it will run anywhere from 100-300 hotter than surface temp of the pipe so a 200degree difference means its about right.
https://www.bigmacktrucks.com/topic/32256-overfueling/page/3/#findComment-216955
didn't think of that. always learning something new. pump is coming off today. thougbt I was seeing oil oming out off exhaust ports, but after thinking about it all night( can't sleep) I bet its fuel. thanks far all your help 84superdog. I'll keep you posted.
https://www.bigmacktrucks.com/topic/32256-overfueling/page/3/#findComment-216963
Got the truck back from Mack today. Runs great. The bypass valve in the tip turbine had a massive failure! It was only found after completely disassembling the tip turbine. Also low on fuel pressure. At some time before I owned the truck, someone added a hose from the top of the fuel filter housing to the return line. No one knows why. They also figured my pyro gauge is between 100 and 200 degrees hotter than actual.
https://www.bigmacktrucks.com/topic/32256-overfueling/page/3/#findComment-217811
Glad you got it fixed, I never would have come up with that without tearing into the truck, I don't know enough about how the tip turbines operate, I'm glad there are still some real Mack mechanics out there.
https://www.bigmacktrucks.com/topic/32256-overfueling/page/3/#findComment-217816
can anyone give me the low down on a tip turbine? how does it work whats its purpose hate being this stupid !! what engines used it ?
pretty good description here with diagram!
http://www.bigmacktrucks.com/index.php?/topic/7899-tip-turbine-cool-power-hows-it-work/
https://www.bigmacktrucks.com/topic/32256-overfueling/page/3/#findComment-217855
  • 4 weeks later...
Over fueling will blow black smoke, running lean is the opposite and will blow white smoke, although not a lot, it leaves more of a white residue in the mufflers. White smoke is more likely oil to be frank. Possibly coolant, but more likely oil blowing past turbo seals. To fix your over-fueling you need to get it tuned. Any zed with a stock tune and boost past 12psi will over-fuel. It's designed to run overly rich to cool the cylinder temps.
https://www.bigmacktrucks.com/topic/32256-overfueling/page/3/#findComment-221691
Burning oil creates BLUE smoke. Unburned fuel is white. Coolant can also be whitish.
Ken
https://www.bigmacktrucks.com/topic/32256-overfueling/page/3/#findComment-221700
