I had the same problem mine was rusted out bad above the rear window, I took the back part off with a small grinder, cleaned the metal up good than used auto body filler and repainted, it looks pretty good. Make sure you prime the metal good I used that xo rust stoper before I filled with the body filler.
I THINK YOU CAN STILL GET DRIP RAIL FOR A RD IT IS THE SAME AS A R MODEL
