Thanks for the replies, I think that VIN decoder is for later trucks like CH. The numbers and letters don't match up. It is a Canadian built truck, but I don't know about a glider. It doesn't show any clues of being one. It has a E6 300L 4 valve with dynatard and a T2070 trans. 12 front and 44 camelback.
https://www.bigmacktrucks.com/topic/32427-vin-help-r-model/#findComment-201285
The B81 is not for sale. What would be a ballpark fair price for the R? It has been off the road since 06. So to start with, it needs 10 tires, and a paint job, then start fixing leaks, change all fluids, belts, hoses, brakes and drums maybe,etc. One could easily spend 10 grand to get it roadworthy and painted and lettered. Between buying a truck like this and getting it on the road, it could easily exceed the value of the truck.
Edited by 55deere70
https://www.bigmacktrucks.com/topic/32427-vin-help-r-model/#findComment-201459
I just sold an '86 R model,300,9 speed,trans. had problems,been sitting about same amount of time as yours,good rubber,but old,shorter wheelbase and steel budd wheels. I got $5k out of it. The place that bought it sprayed up the rims and frame,fixed the trans. and are asking $10950.
https://www.bigmacktrucks.com/topic/32427-vin-help-r-model/#findComment-201493
as far as exceeding the value of the truck,I'd rather have too much wrapped up in a R model Mack,than too much wrapped up in a newer Volvo,Freightliner,Pete,KW,etc. At least you will have a truck still good for many,many,many reliable years of service.
https://www.bigmacktrucks.com/topic/32427-vin-help-r-model/#findComment-201494
