got my answer called eaton then mack e9's use a 10 spring clutch disc ,looked closer at what I took out and found it to be a 8 spring it also contacted the flywheel bolts. smaller dia. spring circle than 10 spring hope this helps someone else!!!!!!
https://www.bigmacktrucks.com/topic/32589-new-clutch-woes/#findComment-203592
