PTO removal from Quadraplex
Phil Bennett
Hello. Wonder if anyone out there can help ? Am based in England (UK) and have a R719LS (1970).
It's has the quadreplex gearbox set up (5spd + 4 spd) and is fitted with a PTO located on the passengers side of gearbox.
I'd like to remove said PTO and 'blank off', but has anyone any advice before I just go undoing bolts etc. Will oil flow out ? Will internal parts fall out ?
I'm sure I can have made up a suitable 'blanking off' plate securely affixed and sealed.
Any suggestions welcome.
Thanks
Phil
  • 3 weeks later...
How did you find an R719 in England? They are a rare truck. As mentioned above, drain oil first, undo the nuts on your PTO/pump assembly, remove PTO//pump assembly, then a gear adapter comes off behind it. You will be left with long studs. Best way is to remove studs and replace with short bolts to go through your cover. Skip
