Try contacting Hale directly. Also Mack will send you the pump operator's manual with the other info about your truck.
You can also PM 1958 FWD; I believe his Dad is a retired Hale employee, so he may be able to help you out.
https://www.bigmacktrucks.com/topic/32701-zf-10-hale-pump/#findComment-204997
LOL Nope, Dad never worked for Hale. Dad retired from JEVIC Transportation in 2005 after 35+ years in the Trucking Industry. He is a life member, Head Wrench-Turner and still active (broken only by his 4-year hitch in the US Navy) in the vollies in Montgomery County, Pa. He also dabbled as an instructor for the early beginnings of the Montgomery County Fire Academy and taught Pumps I and II. However Hale, located in Conshohocken Pa is in our backyard and within spitting distance of the current MontCo Fire Academy. Dad knows many folks over there and can probably tell you anything and everything you want to know about your Hale or Waterous pump.
https://www.bigmacktrucks.com/topic/32701-zf-10-hale-pump/#findComment-205209
