Low oil pressure could be cause, all of the 2000 models had jakes cut out early especially on a hot day when the oil really heats up, not enought oil pressure to the jakes . We put a higher speed oil pump on ours, it helps out but they did make a kit to feed oil from the main oil galley on the block to the jake spacers and feed direct oil to Jakes. If yours have been changed you will have external oil lines on the drivers side going to the jake spacers. I have seen several of the freeze plugs in the end of the rocker arm come out and loose oil pressure, but most of the time that head quits working. See how much oil pressure it has when it cuts off, I think it takes 35 lbs for jake to work so you need to have around 50 lbs on the gauge in truck to work.
https://www.bigmacktrucks.com/topic/32764-jake-cutout/#findComment-205945
Yep, thicker oil = better engine brake for an E7, the high volume oil pump helps a lot.
https://www.bigmacktrucks.com/topic/32764-jake-cutout/#findComment-206003
If you're talking about the external oil lines for the Jakes, you would have to drill and tap the Jake housings to add the fittings. Everything else is pretty simple.
Do you think it would make the jakes more respounceive? I just installed a E7 in place of my E6 and the jakes don't come on as fast as the E6 with dnytrad.They work good but if you use them for shifting they are too slow. glenn
https://www.bigmacktrucks.com/topic/32764-jake-cutout/#findComment-206169
I was just replying to your previous question. External oil lines help if your Jakes are weak or fade away.
Im a little confused on your complaint.
Are your Jakes weak and or fading away?
Or
Are your Jakes strong and cutting out at 1600rpms. Do they feel like they cut out electronically? Meaning, theyre there, theyre there, boom theyre gone.
https://www.bigmacktrucks.com/topic/32764-jake-cutout/#findComment-206633
No what I am talking about when you hit them they come on slower than the ones on my E6 and there is a ssmall delay making it hard to use them to shift with on a hill in low gear.They are strong when they come on just slower than the older engine that was in that truck.
https://www.bigmacktrucks.com/topic/32764-jake-cutout/#findComment-206641
Got it. I would think your complaint is just one of the differences between Dynatard and Jakes. I dont think you can change any parameters for the engine brake. As far as I know, you just have one parameter box to click for the engine brake, on or off. Everything else is set by Mack.
https://www.bigmacktrucks.com/topic/32764-jake-cutout/#findComment-206650
Put a test light in cab of truck and run long wire and unhook one of the jake wire at the valve covers and hook it to it. Test drive see if the light goes off at 1600 rpm, if the light stays on but the jake quits its problem with Jakes internal or oil pressure problems, might need a tune up kit or soleniods. If the light goes off at 1600 it is in electrical but I don't remember a place to set cut off in settings in computer.
https://www.bigmacktrucks.com/topic/32764-jake-cutout/#findComment-207066
