Those wires go to the voltage regulator. The one marked A or G goes to the smae on the volt reg. , the F goes to the F or field . The one that is not insulated is a ground and goes to either a screw on the Volt reg. base or one of the reg. mounting screws.
John Evans,
Trucks & Dogs are expensive!!
https://www.bigmacktrucks.com/topic/328-b-61-generator/#findComment-1407
