automatic meaning allison or an autoshift eaton? E7 meaning an early 07 with an ASET AI engine? the "E7" was turned into the ETECH and ASET AI and AC engines, if its a true 2007 CV713 then it should have an ASET AI engine 370-427-460hp, being a CV713 its a heavy chassis so Dump, refuse, tanker? An early 07 CV713 is a decent truck, it is the newest truck you can get with a real Mack engine, not a rebadged Volvo, check to see if it has had the step 12B update on the ecm and that there are no updates available, they are good trucks that if used properly will last a long while, keep it under 2100rpm and the cam will thank you.
https://www.bigmacktrucks.com/topic/32940-2007-cv713/#findComment-208772
335-434hp isn't anything I've ever heard of before.
https://www.bigmacktrucks.com/topic/32940-2007-cv713/#findComment-208886
