trying to buy this truck w e7 ... in 05 mack did some kind of emissions update on this trk .. im use to an ole e6 smoking !!! this e 7 seems to be somewhat under power and no smoke [black] at all!! what are my options as far as bigger injectors and a bigger turbo ? hauling logs and pulling a pup so i need all the power i can get. IL dyno center has a chip but wondering if there isnt more ?
https://www.bigmacktrucks.com/topic/32949-98-rd-mack/
Is this an etech or Bosch pump vmac 1 truck?
https://www.bigmacktrucks.com/topic/32949-98-rd-mack/#findComment-208890
You would be better of changing your gear train rather than to mess with the fuel or turbo setup. As far as making it smoke, that ain't gonna happen.. The last real smokers we had was in a 4 valve Mack engine in 1989 and you could do a lot of tweaking with those. But all that has changed.. With all engine manufacturers...
https://www.bigmacktrucks.com/topic/32949-98-rd-mack/#findComment-210059
I'd have to respectfully disagree with that statement. My '96 RD with an all manual E7 350 rolls coal like a freight train.
Jake
https://www.bigmacktrucks.com/topic/32949-98-rd-mack/#findComment-210074
