perfect upgrade. should about bolt right in. may have to have the bell housing of the tranny drilled to 7/16's from 3/8's bolts if its olf style and change the front crank hub and pulleys to the one from your old engine. other than that it will bolt right in.
https://www.bigmacktrucks.com/topic/32963-engine-upgrade/#findComment-209046
