I always wondered why a lot of these Airforce trucks were CAT powerered,regardless of make? the Allison auto I get,but never made any sense to me going with the CAT's...................Mark
When I was an Air Force firefighter all the fire trucks were the same no matter where you were stationed. The P-2s, O-6s, O-11Bs, 750As, and 530Bs were the same at each base; it made training easier so
that when you were transferred the equipment was the same. Probably the same with the Cat engines; made it easier for the motor pool if all engines were the same. As was mentioned earlier, vehicles on
Air Force bases didn't travel far or fast. The fact that a lot of these Mack and Dodge refuelers are still in fire department service says a lot about their durability even if they didn't have any panache.
bulldogboy
bulldogboy
You have to love these Departments that never took into account that water is 2.3lbs heavier per gallon than Jet-A and the fact that these tanks are not baffled.....Then they wonder why they are laying in the ditch...........
All fuel trucks are set up with front exhaust. Guess they worry about heat and sparks.
Jet A and heat is a bad combination...
Still the Greatest Name in Trucks...Bulldogs rule, The rest drool....
Member ATHS and ATCA...
