2001 e7 valve adjustment
I have a cx613 with a 460 e7 I went to run the overhead and started at #1 when I got to # I reached over and just rattled #1 and the exhaust had about 1/4 inch play and so did the exhaust on #5 which was the last one done but only on the exhaust valves after adjusting all 6 holes as I went though them it was the same all the way though the last 2 holes done were loss is this normal??? it dose have noise there like the overhead is loss and did to start that's why I run the overhead to start with. I just bought this truck and the oil pressure is low also 12lbs @ idle and the plugs are all in
this engine has 690 jakes and the push tubes are solid not springed. I just haven't had this type of problem before where when you get 3hole done the last to have that type of play. I have an e7 service manual and it have any info on this and I would sure like to get it figured out
ok I have tried to dial to the bottom of the cam and tried to set the exhaust when the intake just starts to close which should put your exhaust on the bottom of the lob and this full thing wont even start you can hear the exhaust valves are open so I set it with the timing marks and it starts and runs great do the epu's run off the cam because it acts like there are 2 stages on the cam? and it still has the 1/4 in play at times on each exhaust. should it have the spring type push tubes? cant find any info on this on the internet. thanks for the help
Yes the flywheel is marked. On the bottom is a small "window" for setting the valves.
Get a good engine barring tool for turning over just enough.
Otherwise, I do not know how, but that's why I pay a guy to do it
Valve adjustment should be done from the flywheel markings , remove the six 8mm bolts from bottom of flywheel housing remove cover marking are 1,6 3,4 2,5 . put marking in window and find cylinder on valve overlap and adjust that cylinder both intake and exhaust ,jake at same time .then turn to next adjustment
I can get every thing set and it runs great but the noise and when you do 1-5 and get to 3 the no.1 and 5 have a lot of play almost a 1/4 in and it dose this thought the hole process you get the next one done and the last couple are loose and when I start back at 1 there right where they need to be.. and a cat turn over tool works great on the e7 the fly wheel is marked clearly . I just need to figure out why I have the rattle and cant get rid of it ,it drives me nuts and that a short enuff trip anyway.
1/4 is normal on a Mack , I would be worried about a cam lobe going down though. Do you hear a high pitched chirp at all ? Did you adjust the valve bridges? And you should try running the engine with the belts off ,the clutch fans can make a lot of rattling noises sometimes.
  • 1 month later...
You don't adjust them on the overlap stroke. If 1@6 are in the window on flywheel housing,check #1 to see if one is tight and one is loose [overlap\ if it is adjust #6 or visa versa. once you get that done you can go in sequence with the firing order. Overlap is when one valve is opening the other is closing, do not adjust on this stroke. The cylinders need to add up to 7. #I on overlap ,adjust 6. #3 on over lap adjust 4. and so on.
Once you get the 1st cylinder done whatever number it might be you can just follow the firing order.
